Tarheel14
My drivers door will not unlock when I stick my hand on the door handle to unlock it passively. I also then try to push the unlock button on the remote and the door will still not unlock. I did change the battery in the keyfob remote and this did not fix the problem. The other day when I had this problem I used the app to unlock it and the app stated drivers door unlocked successfully. I was standing next to the truck and the little lock on top of the door did not pop up. I then used the physical key to unlock the door. When I got inside the buttons on the actual door did not unlock/lock the locks. I then started the truck and the locks started working.
Today I tried my other remote and it worked fine. Then I changed the battery in the initial keyfob again and its now working. But I dont know if this will continue to be a problem.
2019 Ram 1500 Limited.
