I am planning to buy aftermarket wheels and tires and decided that I may as well upsize while I am at it. I really don't want a lot of lift and just want to do a level setup. That said, I have decided that I like the Bilstein B8 5100 Adjustable Lift Struts to do this. I also plan to add a rear Hellwig sway bar. The only mods I have added so far is a tonneau cover, Timber Grove Air Springs, Magnaflow 19433 muffler, and some RC step bars. I don't wheel the truck (have something much more capable for that) but I do tow my 28 foot travel trailer occasionally.
-Will I need upper control arms in order to get factory alignment?
-Can I fit a 35x12.5 without trimming or should I stay safe with 33's?
-Is there a better method or kit to level with than the Bilstein and if so, why is it preferable.
-What is the preferred method of correcting the speedometer after adding larger tires?
My Truck is a 2019 Ram 1500 5.7L Bighorn 4x4 with the ORG. My understanding is that since I have the ORG that the truck sits 1" taller than standard. Thanks in advance.
