If you plan to keep your truck outside of warranty, definitely use a high quality synthetic; not a synthetic blend either, since that marketing term is not regulated and if they put one drop of synthetic in 5 gallons of dino oil they can label it synthetic blend.
You will not get "leaks", I don't know where that idea comes from.
There is a ton of user reports on oiling in a different forum; our hemis do best on high quality synthetics such as Redline, Amsoil, and PUP. This is backed up by Used Oil Analysis reports, most of which are from Blackstone. They tell you exactly which wear metals are present (copper, aluminum, iron etc), in which quantities, and whether you can continue to put more miles on the next oil change etc.
So the science is clear here; use a good synthetic.
