Does anyone run this size ?
PorBoy
Millville NJ
I’m looking to go from my current size to this LT 295/70/18 not necessarily in this brand. I’m also running a Mopar 2” lift just in case.ACC59027-1124-42FF-86BD-C857B1BCE3F5.jpeg
^^^^. Lol, I’m not man enough to be able to run that wheel size. :)
Well it looks that this isn’t going to happen as my wheels are 18x8 and according to the tire sites I need a minimum of 8.5 width wise.
Oh really see now you’ve got me thinking about that size again. It seems to be really hard to find a 18” wheel that isn’t black for these DT models.
Guys run 295 wide on 8" wide stock wheels all the time, its worse to exceed the max width than the minimum, how often do you see people stretching 12.50 wide on 12 wide wheels? Looks dumb AF in my opinion but to each their own.
Perfect, now it’s time to start shopping for that sized tire then. :)
8.5" didn't sound right as a minimum width for a 295, so I checked to make sure. 295 are approved down to 7.5 wide wheels by toyo, nitto, falken, cepek and cooper for sure. I think you misread the site when it says approved rim widths it looks something like 7.5-[8.5]-10. This is actually telling you 3 things. Minimum rim width is 7.5", maximum rim width is 10". The number in the [ ] brackets means that the listed inflated dimensions of the tire were taken with the tired mounted on a rim of this width. In the case of the 295 70 18 nitto g2 you posted, the width of 11.77 and diameter of 34.29 is based on an 8.5" wheel, they're going to be a little different on your 8 inch wheels. Likely going to be a little narrower and little taller 11.5 x 34.50 would be my guess. Rule of thumb is 1/4" change in tire dimension for 1/2" change in rim size. Hope this helps your tire search.
^^^. That was spot and and exactly what I needed to see so that I can now solely shop for that size. I don’t off road nor do I tow or haul, but want a “ beefier “ looking tire to enhance my new hood lol.
Yes I did and for those first three days it was wonderful. Then I decided it was too much wheel for myneeds and dropped down to LT 275/70/18 in the same brand instead. I also went with Toyo Open Country AT / II in both sizes and loved what they afforded me looks and ride wise.
Thats a good height, I have just the Offroad package on mine but will be leveling it out
You do realize that the Chevy truck 6 lug is the same, right? Plenty of wheels made for them.... Just saying.
I’m looking to go from my current size to this LT 295/70/18 not necessarily in this brand. I’m also running a Mopar 2” lift just in case.View attachment 5886
Just order the same size tires, Nitto Terra Grappler G2’s to go with my Alloy Ion 135’s 18x9 as I wanted a bigger side wall vs a 20” wheel and will be ordering my 3.5” Readylift here soon.
