- Jul 25, 2020
295/65/20 is a true 35" tall tire. 35/12.50s are notUpdate: 295/65-20 BFG KO2's ended up at 2700-MM as a circumference that is spot on.
Can you change the factory set TPMS alarm/dash light set points with the AlfaOBD? I want to run my power wagon tires around 50/55 and the computer is set to 60/65.if you've got AlfaOBD, it's a 5 minute process (if that) to change the tire size. I've done a few trucks now to change them and they are all back to being dead on again.
To change the tire pressure thresholds, connect to the body computer, go into car configuration change, and find these two:Can you change the factory set TPMS alarm/dash light set points with the AlfaOBD? I want to run my power wagon tires around 50/55 and the computer is set to 60/65.
