Amazon.com: Quick Charge 3.0 Dual USB Car Charger Socket 12V/24V 36W QC3.0 Dual USB Fast Charger Aluminum Socket Power Outlet with LED Voltmeter for Marine, Boat, Motorcycle, Truck, Golf Cart: Home Audio & Theater
smile.amazon.com
It looked pretty straight forward to wire to source under storage bin that has USB.
There is a thread with pictures and instructions on what fuse slot to use in the fuse box and how to take apart the rear console area for mounting everything. Everyone that has done it used different usb ports but they all looked well done.
Does anyone know if you can add the USB module to the backseat of a Bighorn? I have an empty little cubby hole in the backseat where the module sits on the more upgraded trucks. Just wondering If you can buy the module and add it. I imagine the all use the same wiring harness so possibly just a...
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
