I wanted to paint the black plastic “HEMI 5.7” part of my hood emblem.
I did not see a thread on this and yes I searched.
the process is super easy and takes a few minutes drying time.
I did not paint the the black around the “1500” but the option is there with a few more steps.
pics-
1 stock emblem in place
2 emblem removed- use a trim tool and work around the edges till it pops out
3 emblem ready to be disassembled
4 the seven locations you need to drill the plastic weld out. “Just the tip” you only need to break loose the top 1/16 to release the front plate. I used a 5/32 bit for reference. Gently separate the black plastic from the chrome
5 separated pieces
6 taped off and painted
7 reassembled
8 installed
9 installed
pics-
5 separated pieces
7 reassembled
8 installed
9 installed
