Display said Shift to Park when Driving???
Well, I can't say "has never happened while driving" anymore. Today I backed out of my driveway, shifted to drive, and was on my way for a 15 mile drive to my destination. After about 2 miles that "Shift to Park" message appeared. I was able to retire it by hitting the down arrow on the steering wheel as though I was changing EVIC screens. It repeated the message about every 2-3 miles and I could retire it by hitting either the up or down arrow. Maybe any button would retire it. I stopped at my destination and turned the truck off. Left to return home and the message did not appear again. Nor has it appeared on any trips since then.
There are no effects, no damages, no symptoms, and no codes. I still believe the computer just screws up, is just an anomaly, and it corrects with an ignition recycle. If it happened with any frequency I'd be concerned. For me, the last time this happened was months ago.
I have it every Day almost
Nobody seems to have the solution
I wonder if it is tune related. It happened with my SFT tune and now with my MRT tune.
I wouldn't think it would be tune related. Are you tuned?
My 2019 with 64k miles is in the shop today. It has happed about ten times. They have changed the fluids with very little debri supposedly in it, transmission control module in and reprogrammed the Tranny. I am out of warranty but received a deal about class action law suit on transmission. When I signed in this morning wrote across for m that this was ongoing and no charges. Usually happens when slowing and not coming to complete stop but califnia roll through stop sign. Has also happened when entering intersection and freeway. Have to come to complete stop shift to park and then drive. Going to get rear ended or t boned if not fixed. Say post with one other person named M with a 2019 sounded just like my issue.
It happened to me today as well 2020 Ram Laramie
2020 ram 1500 not etorque, while driving 50mph, truck shuts off, shift p to park message comes on screen. Was able to coast to side of road safely. Got it started again, drove about 2 miles, truck shuts off again. Eventually was only able to drive for about 5 seconds before truck would shut down. Got to a parking lot and was sitting waiting for a tow truck and the dash would light up and the start/stop button would switch to run. This happened multiple times as I sat in the truck. Finally got it to dealer, hoping they can find the issue. It obviously showed no codes when they hooked it up. If anyone finds a solution for non etorque ram please let us know. I’ll post my the fix if the dealer provides one.
Update: short circuit in RF Hub. $1200 fix and I should be good
Anyone ever find out what is causing this to happen? Like most of the people here i am concerned this is going to happen while pulling out into an intersection and it causing me to get into an accident. This has happened to me a few times. Once was when I took my foot off the gas while cruising to a stop. The second was when i was trying to accelerate out of a turn. So it seems like it’s random. Someone I met randomly asked if this was happening to my truck because it also happened to theirs. Dealership was no help and he ended up trading in the truck. I have a 2020 Ram 1500 Limited 4x4 it’s not the eco boost and it just went over 30,000 miles. I already had the shifter knob replaced because it was sticking. Ive seen some people mention they cleaned the throttle body and air flow sensor, some did the reflash, and now someone here said there was a short circuit in the RF hub. So has anyone actually debunked this or could it be multiple issues causing the same problem?
Nope cleaned my throttle body still been happening. Swapped out the crankshaft sensor still happened, it’s been at the dealership for about a week and they still don’t know what’s wrong. It’s pretty clearly a defect in the software. Ford just did a big recall cause of something similar. Not sure what else to do at this point. I’ve been to three different mechanics including a Dodge dealer center
So my dealership is saying it is an issue with the PCM and they are confident that resetting or replacing the PCM will resolve the issue. It’s stemming from something to with the communication between the devices and the throttle body which seems plausible and the reason it’s intermittent. I don’t know enough about vehicles but they seem pretty confident that resetting the PCM to factory or replacing it with an uncorrupted one is gonna solve the problem.
Did this work? I have had my truck in over 5 times….no dealer will do anything because they cannot reproduce and Stelantis won’t accept my videos of it.
Yes it seems to have worked. I did have a pulsar after market tuner in that was removed as well and then they reset the PCM to factory. It’s been about a week though and seem to have had no issues. My dealership has a guy who has worked on these trucks for years so he identified it pretty quick. He said between the tuner and the PCM it was not allowing the throttle body to operate correctly which was what was causing the problem (probably also why cleaning the throttle body has helped a bunch of people). I’ll let y’all know if it comes back but as of now it’s driving good as new!
This has been happening to me for awhile now. When I come to a stop, normally within the first 10 minutes of driving, then it goes away without me touching anything. Started to think transmission but not sure.
2019 Limited- I've had the same problem since purchasing the truck in 2019....several close calls when turning into traffic and have to slow down or stop to put it in park and bakc into drive.... Has been in the shop atleast 6 times with NO ISSUE Found or Could Not Replicate.
It’s the PCM and throttle body, have them clean the throttle body and reset the PCM to factory. If that doesn’t work your PCM may have to be replaced. I had an after market tuner causing part of the problem but after they removed that, and reset the PCM back to factory it’s been running smooth since.
Same shift to park issue, started a separate thread for it. Dealer told me I need a new tranny, which is puzzling because it’s clearly a software/signal type glitch.
After 4 days they finally got these codes to show:
No resolution yet. Very hesitant to spend $4200 on a new tranny only to have it happen again because of a RF or PCM issue.
They reset my PCM to factory, removed the after market tuner I had, and I have not had an issue in over a year; I’d def start with the PCM
Thanks, they told me it’s not a PCM code and now my truck is at the dealer waiting for a new transmission. There are 0 in the country and they said it could be months. They don’t do loaners either so I’m just out my vehicle for an indefinite amount of time.
I'd like to jump in and share my experience with the dreaded "shift P to park" warning notification. I bought a 2020 Ram Rebel V8 used in summer of 2021 and it had 20,000 miles. It ran well for about 6 months then had chronic issues with the "shift P to park" notification happening randomly every other month or so. The notification typically happened as I was decelerating from city street speeds to a stop to make a turn or stop at a light. I would describe the behavior prior to the notification as a skipped down shift when coming to a stop and you could feel it before stopping. The other chronic issues I had were passenger seat heater didn't work, rear window leaked, passenger rear view mirror defrost stopped working, left exhaust manifold cracked, then right exhaust manifold cracked. Each of these issues required separate trips to the dealer to be repaired under warranty. Each trip I complained and noted the "shift P to park" notification but they could never replicate the issue. Upon the 60,000 warranty, I brought the truck one last time to the dealer to check the issue and they couldn't replicate it. I read all the posts on this forum and I couldn't find a trend other than it was something to do with the PCM. Finally, a month ago, a half mile from my home on our city street the notification appeared and the truck died in the middle of the street. I had it towed to the dealer and now they could replicate the issue (I say this with sarcasm). The issue ended up being a broken valve spring on the intake valve of the 8th cylinder. I was 3000 miles beyond the warranty and they covered 60% of the cost which was frustrating but all things considered I was glad they covered some of the cost. The PCM was malfunctioning because it kept trying to accommodate for the broken valve spring and then finally shut down. I got it fixed and bought the extended warranty through Mopar to hedge my bet and give it one more try, hoping this would solve the issue. The truck ran great for about a month and then driving home from church, the dreaded "shift P to park" notification returned. That was it, I loved this truck but it didn't love me. I traded it in the next day before it started having issues again. At this point, I have to assume all the valve springs used in the engine were faulty and they were going to fail one by one. I wished they would have changed out all the valve springs when they had the engine apart but that's something dealers just don't do...they only fix the one issue, nothing preventative. What I learned from my own experience and the experiences of those in this forum is that the PCM is typically not the issue rather it's the symptom to another issue. In my case, it was a mechanical issue. I hope this helps some of you searching for answers like I did prior.
