silver billet
- Apr 18, 2019
I upgraded my lights from halogen to morimoto xb hybrid led's. These come with their own bright white accent strips serving as DRL's, and so I need to turn off the DRL's on my Ram because otherwise the morimoto headlights will flicker on and off several times.
In USA you guys have the setting in uconnect, apparently in Canada our trucks don't have that option.
I did purchase a tazer dt, and it seems to suggest it can do what I want, in two places:
DRL Type: Choose USA (on but selectable), Canada (on all the time), or Off.
DRL Location: Turns, Fogs, or Low beams
The "type" has an "off" which I tried, doesn't work.
The "location" I think also has an "off" setting, doesn't work.
I've tried changing to USA, and then in Uconnect the setting appeared to turn off DRL's. But choosing that setting doesn't actually have any effect.
I had PM'd a member here before my Tazer arrived and he said the tazer can't turn them off, only change the location. That does seem to be the case in practise, but the settings availlable in Tazer DT suggest it should be possible.
Anybody get this working? All I've managed so far is to change the DRL to my turn signals, which is better since now at least I'm not damaging anything, but I want them off completely.
Does AlphaOBD do this any better?
