DEVICE NOT SUPPORTED
Every now and then this message pops up, it remains on even though I press "X" or "ok". it seems to be an update glitch. I have tried all tricks and it just has to disappear on it's own. Anyone else has this issue?
Searching will help.....
Search brings up this thread.
Same here any solution out therr
Also getting it here, 2020 ram 3500 limited. Have ver 40.1 installed for a while now no issues.
I have only seen it when trying to charge something and it will not connect to the data lines of the USB.
Malodave
I made the switch from usb-c to usb-c cable to a usb-a to usb-c cable and haven't had the issue again.
This was after a USB hub replacement, several different cables, and a firmware update failed to fix.
