DEF Tank SKID PLATE made of FELT is Garbage
I had this harness crushed at a tire shop. 2021 skid plate truck and they found the only vulnerable spot. Blew several fuses and lit up the dash. Put the truck into limp in mode, and the def system is the only thing damaged. $1500 later back in action. The exposed harness has a connector and a few sets of wires under the frame, along with the def line to the pump. Not a repair to be made on the trail. Wish I knew about an def skid plate upgrade.
