dmodem
- Sep 28, 2018
Oh, it's 4wd, and that's how they towed it.
This. But only if it's 4wd.
Not smart at all. Even with the transfer case and transmission in neutral it could still cause damage. I wouldn't want the truck back after that lol.Oh, it's 4wd, and that's how they towed it.
Completely agree with you. I’d have refused it be touched and raised hell until a flatbed came.Not smart at all. Even with the transfer case and transmission in neutral it could still cause damage. I wouldn't want the truck back after that lol.
Lo and behold, today was the 3rd time it sat dead in the garage after 3 days. I was able to jump it, but after driving for 10-15 mins, the screen, backup camera, nor climate controls wouldn't work. I called the same dealer and asked if I could drop it off and get a loaner to get back home. He stated they didn't have anything for me to borow, but mentioned something could be waking up a module such as a "microwave in the house". After I inquired whether I should get rid of my microwave, he asked if I had a battery charger and stated the tech said I should disconnect the battery from the truck and charge it with my charger. Once charged, reinstall and see if things wake up. I guess I'm doing Ram's warranty work now on a '19 with 13,700 miles. OK. Got it.So the dealer called and said the only code they saw was for a drained battery but they couldn't explain what would completely drain it after 4 days. Although this is the 2nd time it happened, they told me the only remedy at this point is to start it every other day for 10 mins or so. After I told them how ridiculous that sounded for $60k+ truck, I asked if they'd swing by and start it while I'm on vacation, or have someone stop by airport parking if we're out of town and start it up a few times while I'm away.
Nothing plugged in but thanks.I haven't had a dead battery, but I noticed when I left my OBD reader plugged in that the dash would light up and stay on for 30 seconds or so, over and over. I stood there for several minutes and it just kept doing it. Then I remembered I had left the reader plugged in, and after unplugging it and closing the door it stayed off and I haven't noticed it since. So something with the OBD was continually waking the truck back up, perhaps my phone's Bluetooth connection to it. If you don't use an OBD reader, it's probably irrelevant, but for anyone that does, keep an eye on the truck if you leave it plugged in when not actively using it.
I'll try it. Thanks. I'm also going to pull it out of the garage to the far side of my driveway whenever my boys want to heat Ramen in the microwave. ;-)Sorry to hear about this as it has to be frustrating especially with a butthead for a mechanic.
So, you always park in the garage? Have you tried turning off the auto headlights (headlights to the off position) and then locking the truck with the fob when you exit? The reason I’m asking is I have a neighbor who had a similar experience and he found it never died again simply by turning the headlight switch to off and locking it. This helped the local dealer to find/isolate the issue to the sensor for the auto headlight.
Give it time...I’m certain Numnuts the Mechanic will be demoted to working in the lube bay before long.I'll try it. Thanks. I'm also going to pull it out of the garage to the far side of my driveway whenever my boys want to heat Ramen in the microwave. ;-)
Sadly, these replies come from one of the premier Dodge/Ram dealers in this part of PA.Give it time...I’m certain Numnuts the Mechanic will be demoted to working in the lube bay before long.
Have they replaced the battery?Sadly, these replies come from one of the premier Dodge/Ram dealers in this part of PA.
Well in that case, I’d load up the microwave in the back seat, plug it into the outlet in the rear center console, and invite that ol’ boy out for lunch. Escort him to your truck, heat up a hot pocket, a cup of coffee and then a muffin for dessert.Sadly, these replies come from one of the premier Dodge/Ram dealers in this part of PA.
They're all "premier" if you ask them.Sadly, these replies come from one of the premier Dodge/Ram dealers in this part of PA.
By the numbers, you're right, but it doesn't feel that way when it's happening to you, especially if it's on more than one occasion. My 2021 5.7Hemi etorque Limited is in the shop for the 2nd time for what appears to be the same issue with wrong root cause on first fix. I bought it 3-1/2 weeks ago. It's been in the shop 19 of 26 days I've owned it. They do have issues with the 48V battery and generator/motor. Both of mine have failed, and both are hard to replace. Wouldn't be surprised if the OPs issue is rooted in this. From my understanding the generator/motor charges the 48V battery, which in turn charges the 12V. It also powers most or all of the cars electronics. I'm not sure about engine spark. But it's obviously a very complicated system overall, and as others have stated as with any vehicle these days, electric issues can be extremely hard to tackle, like finding a needle in a haystack.In roughly 1.3 MM Rams sold since 2019...
Crazy question but is there anyone having these eTorque battery issues with an 8.4 radio or do you all have the 12” radio? It appears to be common to those with the problematic 12” radio...
Agree that it’s certainly no comfort to an owner that 99% of the other vehicles made are fine when his isn’t.By the numbers, you're right, but it doesn't feel that way when it's happening to you, especially if it's on more than one occasion. My 2021 5.7Hemi etorque Limited is in the shop for the 2nd time for what appears to be the same issue with wrong root cause on first fix. I bought it 3-1/2 weeks ago. It's been in the shop 19 of 26 days I've owned it. They do have issues with the 48V battery and generator/motor. Both of mine have failed, and both are hard to replace. Wouldn't be surprised if the OPs issue is rooted in this. From my understanding the generator/motor charges the 48V battery, which in turn charges the 12V. It also powers most or all of the cars electronics. I'm not sure about engine spark. But it's obviously a very complicated system overall, and as others have stated as with any vehicle these days, electric issues can be extremely hard to tackle, like finding a needle in a haystack.
