I would look for a water leak somewhere. If it's fogging, there is too much moisture in the truck. Especially in the summer. I do recall seeing a post a while back, that there were a few trucks with body seam leaks at the corners of the windshield.Anyone having issues with there being some moisture/fogging of their gauge cluster interior? Have had no issues for 3 years but just started.
Thanks for the reply, ill look into that!I would look for a water leak somewhere. If it's fogging, there is too much moisture in the truck. Especially in the summer. I do recall seeing a post a while back, that there were a few trucks with body seam leaks at the corners of the windshield.
I had the rear window replaced as there was a leak coming from it, hope thats not it. Coming from somewhere but thanks ill check those out!There should be no fogging as long as the cabin is not compromised.
Could be a windshield leak or a leak in the driver side pinch weld under the fender, check for damp carpet, water under the door opening trim.
Or it could be a cracked rear window frame, leaky third brake light gasket or the shark-fin antenna.
