Dash cam install
Cboozer83
What fuse positions are yall using to get constant and keyed ignition voltages to run a dash cam on a 2022 RAM Bighorn??
A lot of the guys tapped the under-dash fuse block to get constant and switched power. Take a look at this post and the thread is also packed full of information.
Why not go to the original?
Does it really matter if the thread quoted has the answer to his question in it.
Ok. So I just got done installing my camera. I have a red tiger front and rear. The hardwire kit is yellow batt positive and red acc. With a ground. I have my yellow in 33 and my red in 66 in the under dash fuse panel. My camera will come on with the truck started. As soon as I shut it off the camera turns. If I switch them out the camera will only come on with the truck started. I do not have the parking function on my camera. Due to not having, apparently the correct power that the camera wants. What am I missing guys.
