moparleo51
- Sep 24, 2019
okay so i hard wired my dash cam , i used the fuse locations that where recommended here o the site. Fuses - Constant 12V is F33, switched 12V is F66. everything works fine, but after a week installed my ambient temp sensor read 81 when its like 42 out. so when i took my truck in on Saturday they pulled the code and replaced my sensor, after driving it for the time recommend it started working but went right back to a high temp of 70, i took it back and they said maybe its a bad new sensor, so they will check it again when i take it back for the exhaust manifold that's leaking on my passenger side to be replaced . so i then get into my truck this morning heading to my dealer service appointment and my start stop pops up un available now and has an ! after its icon (A)! so when i got there i told them about this too. they said it sometimes does this when the auxiliary battery is low. my question i guess do you believe there any conflict with this? everything is hooked up correctly and it has the box to stop battery drainage with it set at 11.8 volts. i just don't want them telling me this is the cause. i had electrical gremlin they had to trace last April for my sirus and nav. found out it was a kinked wire between the radio and the floor kick panel. took 1 month for them to figure that out. man i1m now wondering if i should get rid of the ram ,but prices are to crazy right now on a new truck. thanks for letting me vent.
