2019rams
- Jun 8, 2025
2019 Ram 1500 4wd. 59,700miles on it.
Had check engine light come on while sitting at idle 3 different times. Light would eventually turn off. Pulled the codes each time and it was Cylinder 8 misfire (P0308). Took it to the dealership and they say they see the cylinder 8 misfire and there is a small misfire as well on 3 and 4. There is small coolant leak in cylinder 8 and they think it is a blown head gasket. They said to get in there and replace the gasket will be $5,000. If it turns out to be cam/lifters it will be about $5,200.
I’m just super lost on what to do. Should I take it to another shop for diagnosis? Not sure where even does that type of work. Or should I sell it without the work done and just get a new truck? It is fully paid off though. Any advice is appreciated. Going to talk to them later today about next steps.
