Currently have my 1500 pop a P0302, replaced plugs, tested coil and engine light is on steady, but when I accelerate it flashes and I can tell its struggling. Fuel Injector possibly?
If you swap cylinder 2 coil with another cylinder and the symptoms don't change, you can then eliminate the coil from the equation.
Once you're sure it's not the coil, swap cylinder 2 injector with another cylinder to see if the issue follows the injector.
If it does, suspect the injector. If it does not, then there's more work to do.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
