Cylinder 2 Misfire P0302 - 2019 Ram 1500
oibedroc
Currently have my 1500 pop a P0302, replaced plugs, tested coil and engine light is on steady, but when I accelerate it flashes and I can tell its struggling. Fuel Injector possibly?
If you swap cylinder 2 coil with another cylinder and the symptoms don't change, you can then eliminate the coil from the equation.
Once you're sure it's not the coil, swap cylinder 2 injector with another cylinder to see if the issue follows the injector.
If it does, suspect the injector. If it does not, then there's more work to do.
Steve
