Big White RAM
- Jan 6, 2020
My 2019 Longhorn has been remarkably quiet, and free from creaks, ticks, wind noise, etc., even when the temperature drops into the 20's. A few weeks ago while driving on a less than perfect road, I started hearing a faint creak/tick coming from the top center of the windshield. I noticed it more the next week or so, only on roads that were not smooth. I figured it was coming from the mirror cover, and when I pressed on it, was able to replicate the exact sound. I removed the cover and panel, added foam pads to the back of the panel so it would'nt move once installed and applied Liquid Wrench Silicone Spray (safe on plastics / paint), then reinstalled. I pressed on the cover, and the creak was gone; however, a tick was evident, so I once again removed the cover. After pressing on everything I could see, I discovered the area causing it. The bracket that supports the camera / mirror is glued to the windshield, and the lower right part where a clip is attached was loose at the very end, causing a tick from the adhesive
