insomniac2k2
- Sep 7, 2019
Hello all,
New to the forums. Just purchased a 19' RAM 1500. It's a Larime Black edition with 22" 6 lug wheels. I will be doing a 2" readylift UCA level in 2 days.
I'm looking to got for a more aggressive look. So far the plan is to go with 20" Fuel rims (Maybe assaults, or something similar.), with 35" Ridge Grapplers.
I have spent over 3 hours reading random threads, so please take pitty on me when you want to just refer me to the search option. Here's what I want to know:
Exactly what offset would i need to run 20x10 rims with 35x12.50r20 ridge grapplers + 2" level? I don't mind the tires sticking out a tiny bit. Just not a ton.
Is this configuration a bad idea? Rubbing? Should I run 20x9 with stock offset? 19.1mm i believe.
Thanks in advance. There is just a sea of information, and all of it seems to be a little different. I just don't want to make a mistake on such an expensive order :/
