I searched through and saw a mention of the two caps both being yellow and somewhat similar but no one admitted to doing the dumb thing I did. I'd like to get some opinions on my course of action.
My washer fluid was low and kept alarming on the gauge cluster. I finally got around to stopping to get some of the green Rain-X washer fluid. It was late, it was dark and I accidentally poured half the bottle into the coolant reservoir. I realized it midway through and stopped. I ended up driving the truck home (8 miles).
Fast forward to today I was going to flush and refill the system. Over the weekend it seemed like the liquids separated. I siphoned out the entire reservoir with a hand pump. I was able to carefully get as much of the green washer fluid out and then I was able to extract the pink/purple coolant and they were very clearly different. I'm sure I didn't get all of it but I refilled the bottle and it's at least as much as I poured in. I'm sure there's been some mixing. I opened the radiator cap and the coolant in there looked fine. I refilled the reservoir with clean coolant/distilled water mix.
So, think it'll be OK or should I go get a full flush?
