Computer Reset with upgrade from 33" to 35"?
RamRebelRob
Upgrading the tires threw off the speedo (which is understandable) - can the dealer fix this?
Also, does the ECU take into account tire size for any of its MPG calculations? Noticed it dipped from 17 down to 13. Didn't expect a 4mpg drop.
djevox
VP of Creative Thinking
MD
Yes, it changes mpg calculations and shift points (if too far off). Some dealers will do it and some won’t, so you’ll just have to call your favorite dealer and ask. You have a couple other options though: buy a diy tire size flashtool, use a TazerDT or alfaOBD, or get an independent off-road shop to do it. (I.e. Trick Trucks, 4wd Parts, etc.)
RamRebelRob
Thanks DJ!
RamRebelRob
Called a couple RAM dealerships and offroading shops in Mesa/Tempe/Scottsdale, no one offers the service, yikes.
djevox
MD
ram!TH@rd
For around $100 or less, you can use alfaOBD to make the change. Here’s a couple searches to get you started.
Search for changing tire size alfaOBD
Official alfaOBD thread
That's what I did.. Had a Samsung tablet laying around and came in perfect for AlfaOBD.. Super easy to do.. Invested less than $80 over-all. @RamRebelRob just keep in mind (Dealer or Self) that changing tire size will disable parking proximity sensors. @RamCares The factory knows about this (or has known) but not ETA on a fix yet.
RamRebelRob
Thank you, what about collision detection?
I was checking out the RAM compatible interfaces on their website and they all appear to be $200-300. Am I missing something?
SD Rebel
San Diego, CA
Yeah, I think I'll go with 34" tires, the speedo difference isn't so bad that I can just live with it.
As for the MPG drop, I had a 1-2 mpg drop on my old F150 by switching to tires just 1/2" larger. Going two full inches should be quite noticeable. Though as mentioned your odometer is likely off, in your favor by the way, but is giving you lower than actual mpg.
I never heard of the parking sensors being affected by changing of tire sizes, that's really interesting.
ram!TH@rd
Yep, here's another thread where a fellow members have the same issue:
One thing I didn't share is that, initially, I had the dealer do a wheel alignment and I did ask them to reprogram the speedo while they had the truck. They performed the tire size change successfully, however, the dealer called me back saying the sensors were disabled as soon as they programed the new tires size. They opened a case with RAM where the feedback was:
RAM is aware that changing tire size will disable parking collision sensors and there is no ETA on fix
I haven't swapped out the parking sensor module as one member has (same thread I pasted) but may give it a shot at some point in the future
SD Rebel
San Diego, CA
Gotcha, so tire size change by programming is what will disable the parking collision sensors. So if I just go with 34" tires and not mess with the programming, I should be fine.
ram!TH@rd
Not following.. Can you share what you searched with regards to compatible interfaces?
RamRebelRob
ram!TH@rd
Probably was following the wrong link, is this what you were referring to?
Yes that one of 3 pieces you need if you want to modify your own setting in the truck's computer
- AlfaOBD software (AlfaOBD)
- Android Tablet (not IOS supported) for AlfaOBD or Windows PC
- Security Gateway Bypass Cable.. You have 2 choice:
- Expensive option (Security Module Bypass | KaodTech)
- Cheaper option which has worked well for majority of us (https://www.amazon.com/gp/product/B08ZL4LRVK/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&psc=1)
RamRebelRob
Hmm, sees to be in line with most of the other after market prices ~$200. Thank you.
$49 - Software
$20 - Cable
$140 - OBD
ram!TH@rd
Av1
I had the parking sensor issue when I was calibrating my speedometer (using Flashcal). What I determined was the parking sensors worked with any rolling diameter input of 33.75" or less. The sensors quit working when an input of 34" and above was entered.
My 35.12" tires (295/65r20) were dead on gps when I entered 34", but I had to use 33.75" so my parking sensors work correctly.
RamRebelRob
Do you know if it affects collision detection too?
Av1
I know the audio and dash indications work now for the collision detection, but I wasn't in a position to verify collision operation when I had 34" input. I have never had it auto brake, even with the stock calibration, so I don't know if that works or not.
