Cold air intake
Like I said, I believe data. Doesn't matter how many people say whether or not a particular intake design is restrictive or not, or how many people drop in and say there have been solid gains with brand x intake. I'm an engineer. When it comes to something like this, I trust the maths lol 🤷‍♂️
Lots of people showing gains on the track and Dragy with .1-.2 off the 1/4 and 1-1.5mph increase. Data seems to say the K&N works really well.
It’s easy to make claims. Coming in and posting about lots of people isn’t data, it’s just you saying it. I’ve only ever seen one post where someone’s claims are backed up with real numbers. But that was one run with an OTR style CAI and one run with the stock intake. That’s not definitive by any means, but at least there was verifiable data. I’m perfectly willing to admit I’m wrong if someone can provide real proof and not just people saying there were gains. Like I’ve said before, I’ve had plenty of cars and trucks with aftermarket intakes, and I’ve never see any real gains on any of them.
In the "Hurricane 3.0 TT" group there is plenty of proof showing time slips and Dragy data that back up the claims. Don't believe it you choose not to but the data and results have been shown and posted.
Yay, this conversation again!
A modern engine- and especially a turbocharged direct injection one - has such a wide range of operating parameters that power output widely varies based on a multitude of things, including fuel quality/octane, intake air temperature, engine and transmission temperatures and much more. Timing and boost are constantly being fiddled with to hit an ever-changing load target determined by the stock tune.
Power levels can easily fluctuate +/- 20hp in a short span of time. This is why marginal claims like “adds 10 hp” or “shaves 0.1 seconds in the quarter” are dubious at best and an outright lie in most cases. It’s nearly impossible to control for exact parameters but it’s really easy to exploit them.
Yes there are theoretically restrictions in the stock intake. In fact a culvert would flow even more air than an aftermarket intake. But there is absolutely no point in serving up more air flow potential than the motor can demand or make use of, certainly not at the expense of filtration effectiveness. Fine grains making their way to the turbo is not great. Not worth the gamble in my mind.
Track gains mean squat. Too many human variables. Show mw before and after dyno runs. Numbers please.
You're definitely giving them too much credit. Just look at some of the OEM intakes and you'll see they're restrictive. I didn't say all. They do it to keep the noise down. Anyways people will argue this until the end of time. Spend your money how you want and don't let others discount it.
Don't just look at something and make a determination. Show us the numbers. Numbers/math don't lie, and don't have opinions.
Yes, both HO and SO platforms. The gains also carried over when trying with a CAT6 type device as well.
Where is the math ? Give us a before and after on the same vehicle on a dyno. Drag strips and race tracks have too much human input, so put it on a dyno and I'll buy the argument.
Even the drag strip can show differences with more than ONE run with the install or stock. Even John Force runs different times, so put it on a dyno with multiple runs. Then take averages. Numbers please.
Dyno slips. Lets see dyno slips. Even reaction times will change the outcome. Take out the human element.
If someone really want's performance gains, they need to get out the check book, and write a bigger check than the cost of a CAI. Externals on a modern engine are not going to do much if anything, unless it's a tuner, and after that, $$$$$$.
Some people just will never accept anything, they are also the same that have never actually dyno'd any vehicle they've owned :) Don't argue with walls.
After putting on my K&N CAI you will definitely hear the turbos and bov.
I put a Filter Wears pre-filter over the K&N filter to keep out any potential water since my sport hood vents are functional.
Hello jmr, just curious as I was wanting to make my hood vents functional, would you be willing to share how you did it?
thankx TJ
aFe has one with 3 different styles of filters, one of them a Dry, synthetic fiber version. not sure if I can post a link,
look up afepower Momentum GT CAI.
TJ
