JeffK2019
- Jan 5, 2019
A lot of smart people on here so looking for some discussion/input. I have read the CAI threads, watched YouTube videos, etc.. but as I take in more data I have more questions. It doesn't help I can't even order my truck yet (dealer says Feb 7th hopefully....). So meanwhile I research the planned modifications once the truck arrives.
First off - does anyone even have data that shows the "cold air intake" actually lowers intake air temps? And I don't see how dyno data really mimics normal driving conditions - having the hood closed alone traps so much heat. If anyone really wanted to document this would be as easy as a sensor mount in the stock intake, do some city and highway driving while data recording, then swap in your CAI of choice and measure the same data. https://www.amazon.com/SensorPush-Wireless-Thermometer-Hygrometer-Android/dp/B01AEQ9X9I
In looking at different brands and data I see a lot of interesting discussion/information on BANKS site realizing most of it relates to diesel applications - but things like intake air temp and pressure change should be fairly similar. If you scroll down on this link - you can see BANKS data looking at various CAI units that actually INCREASE air temp and lower HP.
https://shop.bankspower.com/c-13-products-cold-air-intake-systems.html
I certainly like the intake scoop approach that BANKS has pulling air into the box. At highway speed I would think this could greatly increase air flow. Also having a longer vertical tube to keep debris and moisture away from the intake makes sense to me. The Vararam that people are installing does something similar it seems but I have two concerns: 1) how much of the radiator is the flap that hangs down blocking? 2) moisture - at highway speed and a rain storm just how much moisture is running up into that filter element? I know it has drain holes but the filter could still get saturated pretty quickly. If it was dusty, and now dust + moisture = mud, what does that do to airflow?
http://www.moes-performance.com/Vararam_Air_Grabber_Intake_2019_Ram_1500_5_7L_Hemi_p/vr-hemi-5g.htm
Also if air temp is so important - why are people not wrapping or coating their "plastic boxes" (CAI) in some type of heat shield material? I am guessing that plastic transfers a fair amount of heat into the box area. https://www.summitracing.com/parts/...MI0qDB_qSR4AIVFtRkCh2hGQsdEAQYAyABEgLnevD_BwE
I understand the attempt to lower air temperature is to increase the air density - but does anyone really understand just how much temperature swing is needed to impact air density? The BANKS data above showed swings of 30 degrees F - but we are still talking moving air density around the 3rd decimal point. Plug some numbers into this calculator for fun.
https://www.omnicalculator.com/physics/air-density
Lastly - I felt this guy on YouTube, who clearly knows more than I do about this stuff, had some good points to make. Many really just common sense. It's a bit long at 20 min but I found it interesting.
I will get a CAI for the RAM. Not sure which one yet. I also do some carbon fiber work (hobby making longboards...) and think I can make a pretty nice air ram type intake pulling air from below the grill but back in the engine compartment and up into one of the enclosed CAI boxes.
Sorry for the rant - my wife doesn't really want to talk about this stuff!
