Codes after adding ATC
msnyder1112
Massillon, Ohio
Recently added the uc5 12in to my 2019 that had the basic 8.4. I added the auto temp control sensor/ sun sensor and programmed with alfa.
Dealer told me today that i had a few codes stored related to the heater. I didnt get a chance to write them down, but will get them wednesday.
Anyone familiar with this and is there a way to stop them from storing? Im assuming its with dual atc which i dont have.
That’s going to be normal because you don’t have a dual zone hvac box. You probably have 5 codes stored in the hvac module- 1 for the missing passenger side blend door actuator, and 4 for the 4 missing in-duct temperature sensors.
This is because the only way to have auto climate control work on a DT Ram is to have it configured as Dual Zone ATC (the Single Zone ATC configuration doesn’t work).
None of the faults will affect the way the auto climate control works, you just obviously won’t be able to set different temps for the driver and passenger sides, so you just set them to sync in the radio climate controls.
