Cluster light?
Ortiz7983
Is there a way we can add lights around the cluster like the limited models? I don’t like the limited headlights and grille so that’s why I went with the Laramie. But do like how the clusters light up at night on the limited.
Did you want to change out bulbs in the cluster or add leds that don’t currently exist?
If we could add to have the blue ring outline light or whatever color is wanted. I believe this is just on the limited but was curious if we can add this.
Got it you want the ring. Wasn’t sure if you wanted a simple bulb swap or aftermarket led addon. I haven’t seen anything upgrading the cluster like that. Interesting though. I’ll check around
Thanks!
