tamush.jey5thgenram
- Jun 28, 2023
A few months ago, I had the underside of my 2019 Dodge Ram 5th Gen Limited (5.7 HEMI, 3.92 axle) sprayed with a thick black grease undercoating. Shortly after, I noticed a cranking sound when turning, traced to a loose skid plate and cab bolt, which were tightened by a shop. That resolved the issue then, but now I’m hearing a clunking noise from the front (likely passenger side) and feeling a mild vibration through the gas pedal. It’s subtle, and the engine block doesn’t move or act strangely when changing gears. Has anyone experienced this or know what it might be?
