Clock set it self backwards
Biga
Cincinnati
I noticed the clock in my truck is now reading an hour behind, I have it checked to set by GPS. I see an option to adjust it up or down but I guess I will wait and see what happens overnight once the time change takes place. I have not had this issue before. Not sure if anybody else noticed this on their uconnect?
U
User_119824
Guest
There is a setting in the UConnect interface for daylight savings time. You may want to see if it is set to on. Might have something to do with it possibly.
CDP110
My 2019 on march 11 set the clock back 3hrs on its own. Have it set to gps. I don’t know what happened. Hopefully it fixes itself
CDP110
I yup same here but 3 hrs off. Very weird
CDP110
I looked in settings and could not find anything for daylight savings. It’s either gps or manual
Biga
Cincinnati
Just checked still an hour behind, I do not see a setting for daylight savings time. I went a head an did a manual set for now.
U
User_119824
Guest
Ah sorry.
I remember now. I had to set mine to Manual as it was doing the same thing when I bought it. Not sure why GPS is off an hour, but I had this too.
U
User_119824
Guest
So I got into my truck 30 minutes ago to run an errand and what do you know.....clock was an hour behind.
I changed it manually. No clue what happened.
dano257
New Jersey
Last night mine set itself back an hour. This morning it was set 1 hour ahead and is now on time. Weird stuff...
23RAM
Canada
No issues with my clock this morning - it was set correctly by GPS.
Biga
Cincinnati
Just went to get dinner and clock is now back on time per the GPS. weird, somebody in IT probably geting a little wonky preparing for the time change.
CDP110
My 2019 bighorn went 3 hrs back at 11:00 ish last night then this morning the clock was correct. Gps time. Crazy Weird
6of36
Michigan
I had one vehicle in the past, that set itself the wrong way. I think when it was manufactured, they programmed it to daylight savings when it wasn't or vice versa.
