cheap black dual exit exhaust tips??
ramhouston
Houston, Texas
Could someone kindly present to me some black exhaust tips options for our truck that doesn’t cost an arm and leg? TIA!
Tough to suggest when “arm and leg” is a different price point for everyone. Id check online at your price point and get a pair.
if it was me b2 make a very high quality 5” tip.
Your best bet is look on here for a used set OEM black tips if you don't want to spend a bunch. They will run you in the neighborhood of $100. Most aftermarket 5" tips will run you $225 range. Another option is to get your chrome tips powder coated, most likely $80-100 range to strip and powder coat.
DTS828 provided some good advice. Anyone replacing the factory exhaust with an aftermarket cat-back system will most likely have a set of tips to salvage. AWE is doing my cat-back exhaust in about a month & the black tips are the only component that I am asking them to save. They can dispose of / recycle the rest of the factory exhaust.
You could always paint them. If you prep well, it will look good. Downside is you’ll have to randomly touch them up when they get chips or look sandblasted from road debris.
Do the black factory exhaust tips from the Hemi fit the Ecodiesel and vice versa? Are they the same Mopar part number?
I have the Carven black tips, 5 inch look great.
I got mine powder coated for $40. I’ve got a spare set of chrome ones just in case I ever needed a spare
