Changing coolant on a Pentastar with etorque
19jds76
Has anyone changed the coolant in their truck? I want to drain and refill my system but cannot find the bleeder screw. There are multiple examples online as to where the bleeder screw is on a non-etorque version of the Pentastar V6 but I cannot find any examples for ours.
19jds76
Over 100 views and no answer. I didn't think I was asking that hard of a question. Is no one doing maintenance on their trucks?
mikeru82
The Palouse
I could be mistaken, and since I never considered the pentastar I know practically nothing about them. But my understanding is that all 5th gens with the pentastar have etorque. So if that's the case, a better question might be "how do you bleed the coolant on a 5th gen 1500 with the pentastar engine?".
Are you looking for the drain or a bleeder to burp the air? The etorque generator is basically just an accessory bolted to the engine. I'd imagine the air bleed is in same location
19jds76
I am trying to figure out how to purge the air out of the system. You are incorrect about the bleeder being in the same location. The coolant system is completely different on an etorque vs non-etorque.
There isnt a 5th Gen Ram that doesn't have etorque, but I believe you that it is different from previous generations
