So I had a quater slide down between the cup holder and the lid that closes over the top of the cup holders. I cannot get it out for the life of me, it slides around when I make a turn. Any one know how to take this apart so I can get down in there?
Here you go. Hope it helps.
Oops. You're right.That's not the correct document - he's talking about the lids over the cup holders themselves. The document describes the bench seat console.
Thank you !Here's the correct document in case you need to remove the whole thing:
I like it I will try this before anything else.Have you tried using a butter knife wrapped in double-sided tape? Might be worth a try as taking apart that console looks like a lot of effort! G'luck!
You bet.Thank you !
So after playing with it , the center drink holder splits in 2. Just pull it apart and it snaps right back together
I pulled it apart at the seam, i literally pulls apart and snaps right back together. The lower portion stays in the guide rails.Could you describe this a bit more? Any pics? I didn't want to get too stout on that plastic.
Please give details on how to release the retaining clips to pull the top portion off.I pulled it apart at the seam, i literally pulls apart and snaps right back together. The lower portion stays in the guide rails.
