When I make turns it sounds like a screw is loose in the center counsel. Anyone know how to take apart the arm rest portion to see if there is anything in there?
I had a small rattle that ended up being the rear-most cover of the sliding tray. When the cover was open, there was a faint rattle, with it closed, it's silent.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
