Center console swap 2023 1500 Laramie
Ethgriskolir
Hello. I managed to get the center jump seat out with no issues and the center glove box and trim. The question I have is how do I swap the rear bracket out as mine seems to be bolted down below the carpet in the back as well. Attached are pictures that show the issue.
I need to switch the rear bracket but removing the two top screws did not allow it to come out. Any help appreciated. Rather not cut it out so someone else might be able to use it but will if I have to.
Thank you for any help
Ethgriskolir
Nvm figured it out. Had to remove the seat screws and pull the carpet back. Then lift that plastic piece to get to the two bolts under it that held the bracket in place.
Word of caution need to put the bolts or a different set of bolts in because if you don’t it goes straight out. Noticed my driveway after I pulled them so I put them back in.
Tattoofever6971
Massachusetts
Did mine last yr couldn’t be happier
Actually sold the jump seat to a member on here
Didn’t make much with shipping being so high but better then sitting in my garage
