36Degrees_North
- Aug 16, 2022
If you are interested shoot me a PM I am having more cut.You made that? Thats awesome! I want one.
It's a 6x12 panel with a standard molle spacingI have a laser cutter at work that I can blast one from aluminum.
please post dims.
thanks
Yes 3 are into dead space one does extend into the map pocket area might replace it with a short bolt but so far haven't had an issue with it. I do keep folded paper maps in there depending on the trip.Did you just screw it right into the console?
If take one of these too!Could u fashion one that clips or hangs over the edge so there’s no need to drill holes? I’d buy that for a dollar. (Extra points for anyone who can name that movie quote)
Well played, sir.If take one of these too!
And I can pay for it with my extra points I earned knowing that phrase came from RoboCop
The other issue for me, being here in California, is that we can't leave anything exposed in the truck as it will invite the liberation of said items from said vehicle.
I'll look into seeing if i have the right dies for my press brake to make it. would then need a set bolt to keep it from sliding around and coming out when removing items from it
My issue right now is that my brake can't make that tight of a C bend with the aluminum stock I have been using for these panels. Playing with some ideas in the 3D modeling software I have and talking to my neighbor who owns a wrought iron fence company if they know anyone who has some different brakes and if I can get time on them for a few test prices.This "no drill" design would be sweet. I was thinking the same thing regarding a set bolt or some sort of rubber liners inside the overhang lip that would almost press fit and grab tight.
