yes you can remove it just be careful when you pulling up on it.
Similar question, how do you remove and reverse the coin holder section?
On that note, any suggestions for how to reinstall the rear cupholder for the center console?So, in the picture below the red selected area is the coin holder. If you pull the red circled tab the rubber insert will pull straight up and you can flip it around so that the coins are not visible.
The green selected area is the cup holders. While this can be pulled out it is a bit more tricky. Just below the plastic openings for the cup holders there are rubber flaps that are part of the insert. Those have to be pulled out before the insert will pull the rest of the way out. But, it can be removed. Getting it back in can be equally tricky.
The most difficult insert to remove is the rubber insert for the rear cup holders on the center console.
I’m going to doubt you can just swap the cup holder and coin tray slider for a limited. Probably need two tracks for the cup holder and coin slot and also the cover to slide on.Looking if anyone has an instructions to remove the entire sliding tray. I'd like to swap one from a limited
My truck is missing the rubber insert (bought it used) for the rear console cupholders, and I'm having trouble finding the part number on any of the Mopar parts sites. Any chance anyone wants to pull theirs and see if there is a part number stamped or stickered on the bottom/side of it so I can track one down? Thanks!Use a pry tool to pop the U shaped trim piece around the top of the cup holders. Once removed the rubber cup holder insert is right there, just lift it out.
View attachment 55440View attachment 55441
