So basically this ...Catch Can...is the same as what ole timers use to call a "crankcase & valve cover" evacuation system to avert oily gases from returning thru the intake, re-mixing with the air/fuel, to be burned to support clean burning " ? Like the pcv valve eliminator I have on a 1970 440 that has the crankcase gases going into a catch can, and the catch can has a bottom end petcock for draining.
Are the instructions with the Mishimoto can definitive enough to make it a feasible Saturday morn mechanic add ? What about comments on a truck under factory warranty from a service mnager ? Inputs are sincerely appreciated.
Any made for hemi CC system is easy install. I’ve yet to hear about any issues with warranty. If you don’t drain it and it is the cause of a issue that’s a different situation.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
