Cargomaxx 905HD - and other rear spring options?
ForkHorn
Is there any experience with the 905HD spring? Or a rear spring that will provide 1" plus of rake after leveling?
I take delivery of a 26 BigHorn Hurricane on Monday, and will be leveling/lifting immediately for a 34-35" tall tire.
The easy button seems to be Eibach Stage 2. The problem? Everything I read says you are close to dead level or 1/2" of rake at best. (I know that's the point of a level)
I personally prefer a 1" to 1.5" rake. I look like less of a goober from squatting when I am towing or coming home from the feed store.
So what to do? Sure I could just settle for less lift in the front. But I'm set on needing the full 2.5" or whatever is needed to make a big tire not look so stuffed.
Naturally that leaves me to the rear springs - just go taller. Most of what I'm finding list a 1.5 inch at best lift, or half an inch over ORP/Rebel. (Icon, Bilstein, Eibach)
Options -
Cargomaxx 905HD (listed as 2.5 inch! Or 1.5 inch over rebel)
a 1 inch spacer with the eibach spring
1 inch spacer with the ORP spring
Carli Rebel Spring? (Is it 1" taller than the factory rebel/orp spring?)
The 905HD sounds like it could be a winner. As well as the Carli. I'd rather not use a spacer but it also wouldn't be the end of the world.
Complications? Will the eibach rear shocks be long enough for an extra inch of lift?
Eibach stage 2 with a 1 inch spacer may just be the way to go - definitely the easiest, unless we can find first hand knowledge of the 905HD.
Will Eibach rear shocks handle an extra 1"?
Lots of Rebel guys have done this with the Bilstein 5100's and their factory raised rear rebel spring.
