Car feels moist inside.
Agostino
So I have a 2019 rebel and just had the rear window from replaced about a month ago due to the crack that causes leaking, now whenever it rains it feels really moist inside my car and I can see condensation fog sometimes is the corners of the windows but I can’t find any leaks or wet spots. Anyone else have this issue or am I just being paranoid?
Rock Crawler
Lone Star State
Have you pulled up the door sill trim pieces at each doorway and slid your arm under the carpet? Could be that the carpet pad is still full of water. You might have to remove the seats, prop up the carpet in a few places and run fans. I tried to get the dealership to replace my carpet when my leak was fixed, and they said RAM will not do it unless it was an extreme case like mold and strong musty smells.
  • Like
Reactions: c3k
Agostino
I’ve checked all the carpet and headliner don’t feel anything. Also on a hot day I cracked the windows to air it out but next storm and the feeling is back so I don’t know. I’ll probably swing it by the dealer and see if they can’t verify the window seal or something.
Rock Crawler
Lone Star State
I had two leaks (maybe) at different times. And that was within the first couple months of ownership. First one, they claimed was a door seal. I called BS, but they replaced it. Next time it rained, it leaked again. I came out from work and the inside of my windshield was foggy. So, I knew there was water inside. Second one, they replaced the rear window. Hasn’t leaked since..........yet.
Agostino
Ya my windows get foggy at times also. I’ll mention the door seals, can’t hurt to get new ones anyway.
Rock Crawler
Lone Star State
You will probably have to leave it for a couple of days like I did so they can do a leak test. I’m assuming that they spray water at each possible leak area (shark fin, third brake light, rear window, door seals, front fender well seals/welds, etc.).
kdoublep
USA
In the meantime, I would use some DampRid in there.
