Can Someone Post the Fender Height on Air Suspension Rebel
DavidNJ
FCA didn't publish any Rebel-specific height data in the 2019 Ram 1500 Specs. I'm trying to determine if the Rebel has 1" of suspension lift making it 1.5" taller than a non-Rebel or 1" taller, implying the suspension is only lifted 1/2".
The difference is the 1/2" in height gained from going from a 32" tire to a 33" tire.
Thanks,
David
DavidNJ
Thanks. It indicates that the suspension is 1" higher, with the vehicle 1.5" higher, the extra 1/2" coming from the 33" tires. Is that correct?
With the air suspension, it seems the height increase comes from raising the suspension, effectively extending the spring and trading droop for more bump travel, sort of the opposite of an off-road suspension. Presumably, the steel spring version uses a shock with a longer lower shock body, similar to the adjustments on a Bilstein 5100.
Does the Rebel air suspension also have a longer lower shock body to gain the ride height without losing droop travel? Has anyone measured wheel travel and front and rear?
clazer
Not really sure what the reference height is against, so don’t know?
And yes, the general consensus around here is that it just means you are driving around in off-road 1 when in normal mode.
DavidNJ
For reference, the reason was to decide if we preferred an ORG to a non-ORG. I didn't have a need to raise the truck per se. We wanted the skid plates and electronic diff. The ORG includes them plus hill descent and the HD shocks and is less expensive than buying them separately with the last two not available separately. However, it also changed the height of the air suspension settings...but without published data, we were unclear how much. We would have preferred the truck at the lower height normally.
The ORG also includes a full-size spare which isn't full size and all-terrain tires that seem several generations behind the latest. I wouldn't tow without a spare identical in size to the other tires so intended to change all the tires and the spare tire and wheel shortly after purchase. So those were of less value.
The reference is the 2017, when FCA published data for both the Rebel and other Rams. https://media.fcanorthamerica.com/download.do?id=17681&mid=69. In that spec, most models came with 33" tires, either 285/70-17 on the Rebel or 275/60-20 elsewhere. Some lower-end models had 31.6" 265/70-17. All had an air suspension option, Rebel and Limited had it standard.
Net: The Rebel was a 1" taller than the 265/70-17 and 1/2" taller than the 275/60-17. It was raised 1/2"
265/70-17
74.9​
77​
77.9​
79​
275/60-20
75.5​
77.6​
78.5​
79.6​
285/70-17
75.3​
78.1​
79.1​
These numbers indicate the current Rebel and ORG are raised a full inch plus the gains from a taller tire.
Except that on the Rebel/ORG has no speed limit (or rather the Ram 1500 105mph speed limit) at this height and without the Rebel/ORG they have these restrictions:
Owners Manual Page 299 said:
When in the OR1 position, if the vehicle speed remains between 40 mph (64 km/h) and 50 mph (80 km/h) for greater than 2 0 seconds or if the vehicle speed exceeds 50 mph (80 km/h), the vehicle will be automatically lowered to NRH. Off-Road 1 may not be available due to vehicle payload,
The initial engineering part of the press release said: " an off-road biased rear suspension geometry (Rebel and 4x4 Off-road Package) and unique off-road-calibrated shocks bolster trail capability. " Those sound like comments engineers make in when marketing is pumping them for buzz words to say. However, it also indicates they may have thought about wheel travel. Did they change the lower shock mount? The shock for ORG with air suspension has a different part number. The Rebel Bilstein branded shock with air suspension is yet another part number. There are all different part numbers for the front spindles for air suspension/non-air suspension and 22" wheel/non-22" wheel.
Without knowing wheel travel/extended and collapsed lengths there is no way to know for sure that they moved the lower mounting point to lengthen the shock bottom, but it seems likely that they did. If that is the case the 1" in actual raise should clear a tire 2" larger in diameter. For example, a 285/70-18 (34"), 295/70-18 (34.3"), 285/60-20 (33.7"), or 295/60-20 (34"), A 34" tire with ORG would raise the chassis 2" at normal height over OE 32" tires and non-ORG air suspension. From reports, a 305/12.5 wide tire would probably require a wheel with +12 offset or 6mm spacer in most cases.
clazer
How close are you to a dealer? Before pulling the trigger, I went all through the lot with a tape measure and checking window stickers. Makes for a fun afternoon. The Rebel and off-road group also make modifications to the bumper, I believe.
