Hi all, I've recently sold my F150 ecoboost max tow and looking at half ton rams. I have a Ember 26ets with a GVWR of 7600 and loaded tongue weight at or around 1k pounds. My F150 was a first Gen ecoboost with the 6 speed and 3.73 gears, payload 1568. It pulled the trailer without much fuss but gets hot in a hurry with any sort of hill due to the turbos and high ambient temp, and elevation.
Can I pull this with a hemi with 3.92 gears or will I encounter similar overheating problems. I live at 2k ft and often pull grades from 5 to 7k ft in elevation. How much is the motor going to be screaming in the mountains? I'd love to get a 2500 but they're stupid expensive for a low miles used base model. I only camp 7-10 times per summer so would like to use the truck unloaded the rest of the year, and still fit it in the garage. I've found several Laramie trucks with 1500lb payload so I'd basically be like for like. The ecoboost was pretty quiet even at 3500rpm but stressful watching the temp Guage climb north of 240 and having to back way off the throttle and hit 2nd gear to keep the temps under de-rate at 250.
How does the ram handle mountain towing with this kind of weight? I don't speed, and most of these roads are 50mph max, but twisty and steep in places. I don't need to hear that I need a 3/4 ton truck, and am experienced towing rvs with half tons (12 years this season) and a good wdh hitch handling sway.
