Choppa
- Apr 18, 2021
So I am going to be installing some switchback LEDs soon. The plan is that with the truck running and headlights OFF the LED is in DRL mode. With headlights ON the LEDs are amber. I was planning on using 2 relays for this but wondering if one is ok. My assumption is if I tap F55 or F61 (RT or Left Headlamp) to terminal 86 the Terminal 87 will activate (Amber) if headlights are on and 87a will activate if headlights are off.
Or do I need to run two relays only using terminal 87 on each? Would appreciate any help.
