2021 rebel 5.7 liter battery failed and after replacement the EPB service dahs lamp and a few other dash lamps came on. Using ODD scan I was able to reset the (diagnostic trouble codes) DTC and lamps except for the EPB service dash lamp and a DTC C10D0-52.
I researched the web and forums on how to clear the EPB service dash lamp and C10D0-52 fault but could not find a solution. Many suggestions claim this is a common fault or a ghost fault that can be cleared with disconnecting the battery. However, after consulting a 2021 RAM Service manual, I found that I need to complete an EPB Assembly Check.
I eventually found this EPB Assembly Check function under the scan tool >OBD JSCAN / Adaptation/Vehicle maintenance/ ABS-EPB - Service Procedures.
Once the EPB Assembly check was completed the service lamp turned off. Problem solved! I am sure other scan tools have this function as well.
