Rebelguy2020
It’s was time to install my original summer Duratrac on my truck, a stud broke on the rear wheel when I was torquing it, I did not even reach the torque, it felt weird it just kept turning until the stud completely broke off, the stud threads were stretched. I never use an impact wrench to remove or install my tires to eliminate the wear on the lug nuts.
It was the dealer that had removed the wheels for balancing last fall.
I was lucky that the dealer had a stud in stock, just over $4, and was able to replace the stud by removing the brake calliper and disc brake, thankfully it was the only stud that was stretched, it would have been a big job if my truck was a classic because the axle would have to be removed to replace the stud.
