Dusty1948
- Jul 14, 2018
- Location
- Rochester, New York
Sometime after September of 2018 Ram changed the rear brake pad material and associated rear brake components and revised the part numbers (68412364AB Rear pad kit, 68412365AB Brake Adaptor, and 06512429AA Caliper bolts) and issued TSB 05-001-19 on 10 April, which I think you are referring to. However, these items were in extremely short supply.My truck does this exact thing each morning. I bet the dealer won't apply this TSB though because my build Faye is June 2019 and this applies to trucks built before September 24 2018. Bummer. I wonder what's different with trucks built after Sept 24.
Fifteen days later Ram published a follow-up TSB 05-002-19 to specifically address "rear brake moan" and issued 68446866AA Rear Brake Anti-Moan kit. Last I knew these kits were on backorder.
There's been enough STAR activity on this subject that I would be surprised technicians aren't aware of the issue and whatever the current resolution is. But in any case the dealer's service department should be willing to address the issue.
Best regards,
Dusty
2019 Ram 1500 Billet Silver Laramie Quad Cab 2WD, 5.7 Hemi, 8HP75, 3.21 axle, 33 gallon fuel tank, factory dual exhaust, 18” wheels. Build date: 03 June 2018. Now at: 044446 miles.
