There are apps you can download to your phone that will increase volume, equalizer, etc. Can't recall which one I had but, it was a bit too much and would easily distort.
This is a late response but it might help others. You might check the equalizer or output settings on the app you use to play music. Maybe a pre-amp setting has been turned down on your phone.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
