Has anyone mounted the blend mount without the center link? Id be interested in seeing the pics! Big shout out to securityguy for his walk thru on hardwiring the radar detector to the fuse box!
that looks really clean.Yup. Here ya go
Where did you get that mount?? That is clean looking!
Tom
Any chance you have a link to the thread for using the mirror tap?BlendMount Radar Detector Mounts | Custom Aluminum Mounts
Shop BlendMount and MirrorTap, America's leading Patented Rearview Mirror Mount Brand. Made in USA.blendmount.com
They are custom for the radar detector you have. Then I used the mirror tap system for power. A little pricy but its very clean
I think the thread below has it. Once you pull the plastic cover, there are 2 connectors you can tap into for switched 12V power (don't use constant 12V or the radar detector won't turn off with the truck). I tested with a volt meter first. If you order the mirror tap brand kit, use the smallest size tap and it will take a bit of finessing to get the spade tab into the connector body. Also be careful with the mirror tap wiring in the kit....it is very thin and will break easily.Any chance you have a link to the thread for using the mirror tap?
Perfect, thank you!I think the thread below has it. Once you pull the plastic cover, there are 2 connectors you can tap into for switched 12V power (don't use constant 12V or the radar detector won't turn off with the truck). I tested with a volt meter first. If you order the mirror tap brand kit, use the smallest size tap and it will take a bit of finessing to get the spade tab into the connector body. Also be careful with the mirror tap wiring in the kit....it is very thin and will break easily.
Hardwire radar detector to rear view mirror?
Has anyone done this, or taken the plastic cover off to see if there is a place to tap positive and negative? Also, is there a manual of some sort on the mirror, wiring/ cover removal? It’s a 19 Limited. Thanks5thgenrams.com
