For your nonORP truck, clip 5 will give you 1.7 inches of lift, clip 6 will give 2.2 inches. My suggestion would be to measure your current difference from front to back and make a decision from there. The last thing you want is not enough level, or too much where you’re nose high. If you tow, a bit of rake left will be good to have. There will also be a bit of settling after a few miles. Hope this helps. Good luck.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
