Hi! Just managed to get hold of full set of bilstein 5100, front and rear for my 2022 ram rebel.
Model numbers are:
Front : 24-300872
Rear: 24-233354
Installed front at clip #5 and replaced the stock rear shock with the 5100’s. Upon completion, the front is sitting 1inch higher than the back!
Have double checked everything and all points on this forum, all looks fine in the front. For the rear, according to bilstein technical team (called them) the 5100 should not be used on the rebel. Whereas on numerous web listing it says they can used with 0-2inch lifts in the rear and 0-1inch lift with ORP.
So before I move onto getting a rear coil spacer, has anyone been through a similar process? Any advice will be much appreciated!
Also, is the rear 5100 compatible with a 1inch lift on a rebel/orp?
Tried finding info on the stock bilstein shock, search didnt return anything. Sharing picture incase someone knows.
Model numbers are:
Front : 24-300872
Rear: 24-233354
