RebelWraith
Polymath
You can tell in the picture they installed the spring seat adapter upside down. The circlip is supposed to sit up in a channel under the adapter which in the photos it is flush with the adapter. This will also keep the spring seat from setting fully down. They have added another 3/4" of preload to your springs. Your upper control arm and CV axle angles are bad.
