Pulsar doesn't do it. I have it. You can use it to disable MDS, but that's it on the disable portion.Buy the eliminator, or does Pulsar do as well with added functionality?
That happens even with AutoStop Eliminator.Can’t beat the AutoStop Eliminator. Does exactly as it should for around $100.
I’m not using mine right now because I’m running a Tazer. Strange thing is every once in awhile the Tazer will still activate Stop/Start at random every few weeks even though it’s disabled in the settings.
No, can't be done. It's not a simple switch.I don't have start/stop, but I question if there's a jumper wire that can be added to the switch to make the switch always think it's off. Is there a switch?
On my F150, someone posted a how-to on the wiring to the auto start/stop switch. That how-to stated what pins to jumper to force the switch to seem always pressed, so upon starting the truck, the start/stop was automatically disabled. Can this be done on the RAM? $100 seems excessive if a simple jump wire will do the same at the switch/button.
Depending on what your future plans are for the truck, an unlocked pcm with a tune can disable AS/S. I have found that to be one of the added benefits when I went that route.Buy the eliminator, or does Pulsar do as well with added functionality?
Even with a tune it turns back on sometimes.Depending on what your future plans are for the truck, an unlocked pcm with a tune can disable AS/S. I have found that to be one of the added benefits when I went that route.
Mine hasn't.Even with a tune it turns back on sometimes.
What tuner do you have?Mine hasn't.
I have the same, Diablosport unlocked pcm and i3. Two months in, no issues.What tuner do you have?
I have an Intune I3 and if I disable start-stop it doesn't stay off and every once in a while it goes back on.
Maybe that's why only 2 months. I've had mine for over a year on this truck. It works fine for a while then resets to toggable. Same thing using a Tazer or the auto start-stop elim cable.I have the same, Diablosport unlocked pcm and i3. Two months in, no issues.
Tazer didn’t disable my S/S. It does some things well but not that. If the Diablo stops functioning correctly I’ll have them rectify it, but I expect it should be fine. I’ve had their stuff on 3 vehicles now, overall satisfied with their products .Maybe that's why only 2 months. I've had mine for over a year on this truck. It works fine for a while then resets to toggable. Same thing using a Tazer or the auto start-stop elim cable.
